CM 64 and copy channel
Postby sjordan93436 » Fri May 27, 2011 4:18 am
CM 3.3.5
No big deal, but CM 64 does not seem to copy channel.  CM 32 does.  I open an image, select a channel, click the icon, apply.  Then control V or paste is empty.
BTW, I was trying to use CM and curve and then paste the channel into a mask.    PS pastes into a new layer.
Steve
Postby -default » Fri May 27, 2011 4:45 am
Thanks, Steve.  People have reported this bug a number of times, but I believe I missed the fact that it was a 64 bit only problem.
Re pasting to a mask: try alt clicking on the mask before pasting.
Postby sjordan93436 » Fri May 27, 2011 2:59 pm
Thanks.  Keep up the good work.
Users browsing this forum: No registered users and 85 guests
