As Curvemeister develops, we'll be taking some things away, as well as adding new features. The ribbon is fairly expensive in terms of screen space, and development effort.
Is the ribbon really useful to you, or would you just as soon see it go away in the next major rev of Curvemeister and be replaced by something like user configurable toolbars?
BTW - most people do not know Curvemeister can already hide the ribbon, and you can configure your own toolbars and buttons.
Ribbon: should it stay or should it go?
Hi Ron,
Good to hear from you!
As Curvemeister gets more and more features, I'd like to consider streamlining features that turned out to be not that useful, to keep the program smaller and simpler. The Ribbon is one obvious area for consideration, but if there are people who like having it there, we could keep it, and simplify other areas.
Hello.
I personally like the ribbon. I also use and have customized the "toolbar" of icons to get to certain options faster. I also extensively use the options from clicking the mouse; for example I select the mouse option (new sample point) for adding a hue clock rather than using the Alt-Click. I also use the mouse option to select the shadow, highlight, etc.
One enhancement I would like, is to make the "black" dots for as elected point on the curves darker or even a color other than black (color of curve) so it is easier to differentiate the point from the curve. Perhaps, you can add a setting that would permit the user to select the color of the "dot" on the curves.
Hope this information offers you some insight into the manner in which I use CM.
Thank you
David Krassen
Thank you
David Krassen
Users browsing this forum: Bing [Bot] and 5 guests
