Week 6 - Example 6 - Harbor View
dkrassen
Postby dkrassen » Sun Jan 30, 2011 4:47 pm
Hello.
I decided to select the white areas that should not be changed,  boats, then invert the selection and finally use CM.  With CM, I used the K channel with maximum black setting.  I adjusted the K channel mask and then darkened the sky.  I posted a snapshoot of the mask with the red areas showing the selected areas to exclude from the CM adjusted to emphasize the selected areas.  I got the idea of the technique to work.  Overall, this image came out good.  What do you think of it?
Thank you
David
20110130_example5-harborview-kchannelmasklab1_screenshot1a-jpg
20110130_example5-harborview-kchannelmasklab1_screenshot1a-jpg (999 Bytes) Viewed 20498 times
20110130_example5-harborview-lab1_screenshot1b-jpg
20110130_example5-harborview-lab1_screenshot1b-jpg (999 Bytes) Viewed 20498 times
Postby ggroess » Sun Jan 30, 2011 9:47 pm
I would agree with you...overall this image came out good...
Nicely done...
