Richard Week 6 Ex 6: Sun Moon Lake
Postby mikemeister_admin » Fri Jan 28, 2011 12:12 pm
I made selections on the two buildings and the two boats and used the B channel for the mask.
The first image uses the selections, the second image is from the previous lesson without the selections.
Richard
c1s6-example6-bmask3-jpg
c1s6-example6-bmask3-jpg (999 Bytes) Viewed 28825 times
c1s5-example2-bluemasklab2-jpg
c1s5-example2-bluemasklab2-jpg (999 Bytes) Viewed 28825 times
Postby ggroess » Fri Jan 28, 2011 9:19 pm
Which do you prefer??
They both look reasonable...
I have a favorite but I want to hear what you think first...
Postby mikemeister_admin » Sat Jan 29, 2011 12:58 pm
Except for the boat in the center of the image, I actually prefer the bottom image without the selection. The top image is slightly dark and the sky mask on the top right hand side isn't as well done as on the bottom image.
Richard
Postby ggroess » Sat Jan 29, 2011 4:19 pm
see..you are getting the information...good call.
That is exactly what I was thinking..I liked the top image for the boat; but the tonality of the bottom image makes it the better one overall.  You can go back into the top image an lighten it but then the mask issues will become more visible.
