Week 5 - Example 7 - Flower Vendor
dkrassen
Postby dkrassen » Thu Jan 27, 2011 12:17 am
Hello.
I adjusted this image in RGB.  I applied three neutrals, a shadow and a highlight.  I also manual adjust some of the neutrals.  What do you think of this correction?
Thank you
David
20110126_example7-flowervendor_rgb1_screenshot1-jpg
20110126_example7-flowervendor_rgb1_screenshot1-jpg (999 Bytes) Viewed 6000 times
Postby ggroess » Thu Jan 27, 2011 5:17 pm
It looks quite nice...
One of the issues is the window behind the man...Can you open that up without messing the rest of the image up?? Not required..but good experience...
You can take a second pass at this in a different color space if needed once you have the color correct.
