Steve week 6 ex 2 temple
Postby sjordan93436 » Tue Jan 25, 2011 7:33 pm
I made two passes.  First in cmyk to correct some shadows, add a touch of blue to sky, and open some shadows.
In LAB, I bumped the color and went back down with the K slider.
I think the K slider does the same as the opacity slider, but since it is in CM you can mess with the curves and see "final" output.
Finally, you might want to check out the hue clocks.  With a K mask, sometimes I would not see the alternative numbers on the clock.
62sj-jpg
62sj-jpg (999 Bytes) Viewed 9753 times
62ss-jpg
62ss-jpg (999 Bytes) Viewed 9753 times
62ss2-jpg
62ss2-jpg (999 Bytes) Viewed 9753 times
Postby ggroess » Tue Jan 25, 2011 9:38 pm
Here is what you did with this last time...Just an FYI...
62-pagoda2-jpg
62-pagoda2-jpg (169.4 KiB) Viewed 9753 times
Postby sjordan93436 » Wed Jan 26, 2011 12:28 am
I don't like blank skies.  I think the subtle cmyk move was better for the skies.  Then the LAB move made them blue.
Postby ggroess » Wed Jan 26, 2011 3:54 pm
I think you have done a fine job...
I posted the old one for you to compare your own work...
Postby sjordan93436 » Wed Jan 26, 2011 4:28 pm
I did not look at old versions just to increase educational value.  But this version for some reason if much better.  I think I target the sky separately before, here is the advantage of smooth curves over blend if or selections.
