Week 5- Example 4 - Masked Lemurs
dkrassen
Postby dkrassen » Mon Jan 24, 2011 7:37 pm
Hello.
I performed the lemurs example using smart filters.  I did not notice this before but when using the Smart Filters even though I checked the smart filters icon in Curvemeister,  I sometimes have to re-check it when accessing Curvemeister via a smart filter - it does not always remember this check - Why?  So, everything is fine with retrieving the channel masks in Smart Filters; I just have to make sure the smart filter icon in Curvemeister is checked when going into Curvemeister via Smart Filters.
Now, for the Lemurs exercise.  I use Lab and chose the Lab B channel to mask the eyes.  After adjusting the curve to make the eyes as white as possible, I inverted the mask.  I then adjusted the saturation and finally selected a neutral.  What do you think?
Thank you
David
20110124_example4-lemurslab1-channelbmask_screenshot1a-jpg
20110124_example4-lemurslab1-channelbmask_screenshot1a-jpg (999 Bytes) Viewed 5897 times
20110124_example4-lemurslab1_screenshot1b-jpg
20110124_example4-lemurslab1_screenshot1b-jpg (999 Bytes) Viewed 5897 times
Postby ggroess » Mon Jan 24, 2011 9:21 pm
I like your solution...nicely done...
