Week 5 Example 3 - Darken Sky # 2
dkrassen
Postby dkrassen » Sun Jan 23, 2011 10:01 pm
Hello.
This is another scene where I am darkening the sky.  I, again, used the K channel as the Mask and attempting to make the sky as white as possible and the rest as black as possible.  I then change the L curve and adjusted the saturation.  This sky maybe over saturated but I wanted it to stand out to demonstrate the technique.  What do you think of this image?
Thank you
David
20110123_example3-darkensky_lab1-channelkmask_screenshot1a-jpg
20110123_example3-darkensky_lab1-channelkmask_screenshot1a-jpg (999 Bytes) Viewed 6023 times
20110123_example3-darkensky_lab1_screenshot1b-jpg
20110123_example3-darkensky_lab1_screenshot1b-jpg (999 Bytes) Viewed 6023 times
20110123_example3-darkensky_lab1_screenshot1c-jpg
20110123_example3-darkensky_lab1_screenshot1c-jpg (999 Bytes) Viewed 6023 times
Postby ggroess » Mon Jan 24, 2011 3:27 am
If you play around with the light end of the L channel you might be able to hold the tone in the clouds...
The color looks POWERFUL....
I love it...I'd never do that for real...but it is fun to play...
If you have time and you want to play around give it a shot...
