CM Week 4 Example 6 - Painting a Fire Truck Green
dkrassen
Postby dkrassen » Fri Jan 21, 2011 7:21 pm
Hello.
Painting a red truck greens involves the clever truck of inverting the a channel of Lab Mode.  Unfortunately, part of the fireman's face also turned green.  How would you recommend I correct this situation.  I suspect masking techniques could be used to confine the green to the truck and hopefully will learn more about that them during the next two weeks of lessons.  How do you like this image?
Thank you
David
20110121_example6-lab1_maketruckgreen_screenshot1-jpg
20110121_example6-lab1_maketruckgreen_screenshot1-jpg (999 Bytes) Viewed 5739 times
Postby ggroess » Fri Jan 21, 2011 9:13 pm
Bend the curve in the middle to a 90 degree angle.  The harder the bend the better the face will look.
