CM Week 4 Example 4 - Dog with Mask
dkrassen
Postby dkrassen » Fri Jan 21, 2011 4:55 am
Hello
I see much potential for the use of Masks within Curvemeister.  I do, however, wonder what would I do if multiple objects were selected by a Mask and I only wanted one object or part of an object to be selected?
I posted both a screenshot of the dog mask and a jpg of the dog in purple.  What do you think?
Thank you
David
20110120_example4-lab1_dogmask_screenshot1-jpg
20110120_example4-lab1_dogmask_screenshot1-jpg (999 Bytes) Viewed 5530 times
20110120_example4-jpg
20110120_example4-jpg (999 Bytes) Viewed 5530 times
Postby ggroess » Fri Jan 21, 2011 8:27 pm
In CM you would be stuck with the selection...that is why CM allows you to paste to a PS or PSE layer and then you can paint Black on the mask.
In fact if you wanted you could paste the mask into two separate layers and edit each mask separately.
Purple is a great color for a golden retriever....
