CM Week 3 Example 4 - Monkey
dkrassen
Postby dkrassen » Tue Jan 18, 2011 12:39 am
Hello.
Unfortunately, I am still behind because of my medical problems.  I am trying to catch up.
I performed the corrections in Lab mode using the skin pin and without using the skin pin (manually).    The results are slightly different.  I personally like the one that used the skin pin better.  What do you think?
Thank you
David
20110117_example3-lab1_skinpinscreenshot-jpg
20110117_example3-lab1_skinpinscreenshot-jpg (999 Bytes) Viewed 5512 times
20110117_example3-lab3_manualscreenshot-jpg
20110117_example3-lab3_manualscreenshot-jpg (999 Bytes) Viewed 5512 times
Postby ggroess » Tue Jan 18, 2011 2:51 am
I would agree the pin helps your correction.
But it does so in two ways...Color is 1 and brightness is another.
If you drop the brightness so that the manual correction has the same L value they might be closer together in the correction.
