Richard Week 4 Ex 3 Tigers
Postby mikemeister_admin » Thu Jan 13, 2011 10:57 pm
Between LAB and RGB, I prefer the color in LAB.
Richard
c1s4-example3-lab3-jpg
c1s4-example3-lab3-jpg (999 Bytes) Viewed 7640 times
c1s4-example3-rgb-jpg
c1s4-example3-rgb-jpg (999 Bytes) Viewed 7640 times
Postby ggroess » Fri Jan 14, 2011 4:52 am
I do too..
Try this next time...
Correct the color in RGB.
Apply the changes and exit CM...turn right around and go back into CM in LAB and adjust the color..
If you have the neutral right you can really push the color around...
Postby mikemeister_admin » Fri Jan 14, 2011 9:21 am
I re-opened the RGB correction in LAB and made some small corrections to all 3 channels. I think that it improves the RGB correction that I originally made.
Richard
c1s4-example3-rgblab-jpg
c1s4-example3-rgblab-jpg (129.81 KiB) Viewed 7640 times
Postby ggroess » Fri Jan 14, 2011 6:54 pm
Absolutely...
Wonderful correction...
