Richard Week 3 Example 3 Skin Tones
Postby mikemeister_admin » Mon Jan 03, 2011 4:11 pm
Corrected using the skin 1 pin in LAB. Is there a particular reason why you asked us to use only this pin as compared to the SHN skin tone pins that you privided?
Richard
c1s3-example3-20-bad-skin-toneslab-jpg
c1s3-example3-20-bad-skin-toneslab-jpg (999 Bytes) Viewed 5549 times
Postby ggroess » Tue Jan 04, 2011 4:42 am
This was actually written before the SHN pins existed.
If you want to try the SHN pins by all means do so...you hit it right in all the images by the way...
