Richard Week 3 Example 2 Fruit Multiple Neutrals
Postby mikemeister_admin » Mon Jan 03, 2011 2:58 pm
When placing multiple neutrals, I have the impression that the second neutral that I place "negates" the first neutral in the sense that the RGB values of the first neutral are no longer equal. Is that correct or am I missing something?
I have not been very successful in making the hue clock hands very short. When one gets shorter another seems to get longer.
Richard
c1s3-example2-neutrals-jpg
c1s3-example2-neutrals-jpg (999 Bytes) Viewed 9105 times
Postby ggroess » Tue Jan 04, 2011 4:41 am
What version are you using of CM...There is a bug in one of the recent versions where the multiple neutrals do not work together...there is a fix coming but I want to make sure you are not trying to do something the software is broken over...
Postby mikemeister_admin » Tue Jan 04, 2011 10:59 pm
I am using Curvemeister version 3.2.5.
Thanks,
Richard
Postby mikemeister_admin » Sun Jan 09, 2011 9:12 am
Hi,
Did you ever find out if there is a bug in version 3.2.5 that I am using for multiple neutrals?
Thanks,
Richard
Postby ggroess » Wed Jan 12, 2011 4:31 am
Not to my knowledge..I am seeing some bugs in versions above that one...I would stay there for now...
