Skin Tones: Advanced Work Flow
Postby ggroess » Thu Dec 30, 2010 9:02 pm
When you work on skin tones in CM one of the biggest hurdles is knowing what "Skin Pin" to set.  I have created a few resources for you to use and build upon.
The first is a JPG image that I have posted that has an extended range of skin tones for you to choose.
Lastly is the work flow...
Postby sjordan93436 » Mon Jan 03, 2011 1:04 am
I noticed that pinning changes the points of the curve so that they match the pin.  The hue clock hands will point in the same direction as the pin's hue clock.  But the luminosity does not change.
A blue jeans pin would be good.
Besides checking the length of the hue clock hand, is there a better way to check saturation?  What numbers should I be looking at?  I have installed a clock watcher and will monitor the S of HSB.  Generically, my biggest mistakes have been over saturation.
Postby sjordan93436 » Tue Jan 04, 2011 11:54 pm
I hair color unreliable?  Is black hair black?
Postby ggroess » Tue Jan 04, 2011 11:58 pm
A qualified depends...
I would say a black haired person would have what we call REALLY.. really..dark Brown.
But I am sure having just typed this that I am wrong.
I think at that point it matters not if the color is 100% Black because the inks and pixels used to produce it are not perfect either...
