CM Week 2 Example 7 Taroko Gorge
dkrassen
Postby dkrassen » Mon Dec 27, 2010 10:00 pm
Hello.
I tried this image in both LAb and RGB.  I personally like the Lab correction better, however, it may be a little bright and have too much color.  I suspect the RGB version is more realistic.  None the less, I prefer the Lab version.
What do you think of them?
Thank you
David
20101227_example7_lab1screensshot-jpg
20101227_example7_lab1screensshot-jpg (999 Bytes) Viewed 6344 times
20101227_example7_rgb1screensshot-jpg
20101227_example7_rgb1screensshot-jpg (999 Bytes) Viewed 6344 times
Postby ggroess » Tue Dec 28, 2010 9:18 pm
David,
One of the first things I do when we get to this point of the class is over-saturate your images to see if you have a solid neutral setting.  It's quick and easy to do...
Take your LAB image and over saturate it...Shot1...
You might want to look for another neutral.....BTW this image can stand a ton of saturation...
RGB suffers a similar fate....
shot1-jpg-13
shot1-jpg-13 (264.86 KiB) Viewed 6344 times
