CM Week 1 Example 7
dkrassen
Postby dkrassen » Sun Dec 19, 2010 3:41 am
Hello.
Again, this one was very confusing even with the hints.  I gave it a try in both RGB and Lab but do no really like the results.    In the RGB trial, the 2 is somewhat gray - Why?  In the Lab, the 2 is better but still not perfect.
Please post a correct acv file for both RGB and Lab versions of the image correction.
What do you think of the images below.
Thank you
David
20101218_exampe7_labscreenshot1-jpg
20101218_exampe7_labscreenshot1-jpg (999 Bytes) Viewed 6154 times
20101218_exampe7_rgbscreenshot1-jpg
20101218_exampe7_rgbscreenshot1-jpg (999 Bytes) Viewed 6154 times
Postby ggroess » Sun Dec 19, 2010 6:04 pm
This is really about thinking beyond what you would think of doing to an image...
Here is a screen shot and a ACV file..
screenshot001-jpg-26
screenshot001-jpg-26 (76.01 KiB) Viewed 6154 times
c01s01-example7-lab-acv
(74 Bytes) Downloaded 607 times
screenshot002-jpg-21
screenshot002-jpg-21 (81.58 KiB) Viewed 6154 times
c01s01-example7-rgb-acv
(74 Bytes) Downloaded 620 times
