Feel free to make this into anything you want....
Extra points for creativity.... 8)
Open for your interpretation
Just over 3 years ago (yes, I'm an ancient user of CM 8)) Mike had this page on Black and White conversion through CM . Don't know if it's still there (screen shot 0001). I'm still using it and found that there's more control using the curves in RGB through CM than the sliders in PS. So, here's my B&W effort http://www.curvemeister.com/forum/index.php/topic,1392.0.html
- screenshot0001-jpg (111.5 KiB) Viewed 15989 times
- gjg_0027a-jpg (136.73 KiB) Viewed 15989 times
I leaned hard on the contrast in the brightness chanel in HSB to separate the ice flakes from the sky,then when I went to change the sky in saturation I got a B/W conversion which I was going to try anyways.Hard sharpening for the ice edges.
For the color version I started with the HSB con trast then changed to Lab for the color(file below)In a second pass in Lab I put a neutral on the ice to get a whiter white and better sky.GregM
- gjg_0027-copy-jpg (282.67 KiB) Viewed 15989 times
- gjg_0027-copy2color-jpg (255.15 KiB) Viewed 15989 times
- hsb-jpg (264.51 KiB) Viewed 15989 times
- gjg_0027-copy-lab-acv
- (66 Bytes) Downloaded 891 times
Hello
I am posting two versions of the branches in the sky image. I used levels and curves. I used both in RGB mode. It is my understanding that you can perform the same corrections in CM that you do in levels but I am not sure how to use Curves or CM in this manner. Even my Photoshop Curves adjustment uses auto as a starting point. I am relatively new to curves and hope this class will answer most of my questions.
Please post any suggestions.
Thank you
David Krassen
Thank you
David Krassen
- 20101210_gjg_0027_curves-jpg (281.93 KiB) Viewed 15989 times
- 20101210_gjg_0027_levels-jpg (270.49 KiB) Viewed 15989 times
