Curvemeister Wizard...Troubles??
Postby ggroess » Thu Dec 09, 2010 8:48 pm
I just tried the CM wizard in CM 3.2.4.
It made a total mess of the image in LAB mode. RGB seems fine... I am going to download the latest version and see if it does the same thing...
If it does I'll have to adjust the first assignment in CM so please be patient with yourself as you look at images with the wizard.
Postby ggroess » Fri Dec 10, 2010 3:31 am
OK...The LAB wizard in CM 3.2.5 is still having problems...
Therefore...when you do use the wizard for the first weeks assignment please stick to RGB.  If you want to do the LAB corrections go ahead and do that but the parts that ask you to use the wizard with LAB can be skipped.  We will be turning off the wizard almost right away in any case...
We have to take the training wheels off fast...
Postby -default » Fri Dec 10, 2010 6:02 pm
OK - I'm pretty sure I fixed this bug, though now that I think about it, the code I changed has been the same since Curvemeister 1!
Now the only hurdle is to get curves ship shape again.  I've eliminated the OCX by moving all the curve functionality directly into Curvemeister.  As you can imagine, there were quite a few sparking wires hanging out during this process.  There a few more bits that need to be reconnected.  The next beta will we usable, but will probably contain some interesting bugs in the curve interface.
