Greetings!
The attached document is new for the class...
This is an overview of some of the basic Curvemeister interface features and is a work in progress.
Comments are welcome but please send suggestions to me at greg@curvemeister.com
Curves interface article
- understanding-the-cm-interface-rev1-pdf
Dear Gregg,
Thank you for this overview.
I have two questions which are related. In the second paragraph on page 10, you mention that for the highlights, you need to work in the lower right of the grid and that shadows are in the upper left. With the layout that is given on this page, I don't understand why these aren't the lower left and upper right, respectively.
Perhaps I am confused because coming from Lightroom, I am used to seeing the light side (RGB 255) on the right and the dark side (RGB 0) on the left. Is there an advantage to put the darkness on the right?
Thanks,
Richard
Thanks,
Richard
There is no difference in how the curves behave..
It is completely up to you. I grew up on exposure curves and film test strips. The Shadow on the right matches that experience. The text simply follows the screen shots. In CM you can reverse the curves by clicking on the "grid flip tool"
As we go forward just remember that your curves will be opposite of mine when I post screen shots.
Thanks for the pdf.
I had a crazy idea. I am sure it either does not work or been there done that.
If you could click on a hue clock and hold down the button. Left / right could move the hand left and right. Up and down could make it longer. Third axis is a little more difficult. Scroll wheel? Alt up / down? It would move the point that would be marked by the hue clock on the appropriate curve(s). It would be a bear to program and I am sure Mike has enough work...
I am a little punchy today due to lack of sleep. Did I explain it? Sort of TAT on steroids.
