julie view from temple
Postby imported_julie » Thu Oct 28, 2010 2:04 am
Hi Greg
Had a bit of trouble balancing the need for less cyan and the need for the neutral rather than magenta clouds. this is the best result I could get
view-from-temple-jpg-2
view-from-temple-jpg-2 (999 Bytes) Viewed 25628 times
view-from-temple-jpg (999 Bytes) Viewed 25628 times
Postby ggroess » Thu Oct 28, 2010 3:15 pm
This is related to the K channel as well...
Try this with the L channel mask instead.  There is a ton of "Drama" that can be added to the sky.
shot1-jpg-20
shot1-jpg-20 (258.96 KiB) Viewed 25628 times
