Steve lake week 6 number 6
Postby sjordan93436 » Sun Oct 24, 2010 10:09 am
I decided to brighten only the sky.  So a very rough selection on below the sky line.
66-lake-2-jpg
66-lake-2-jpg (999 Bytes) Viewed 31698 times
66-lake-2-ss-jpg
66-lake-2-ss-jpg (999 Bytes) Viewed 31698 times
Postby ggroess » Tue Oct 26, 2010 3:19 pm
Remember to use a bit of caution when you hand paint out the mask in PS so that you cover the entire image you want to mask...You handled the sky nicely...
Postby sjordan93436 » Tue Oct 26, 2010 5:30 pm
I find it better ...  if I use the PS mask then I convert the mask to a selection, then go to CM.  I can see the mask in the ruby color or not.
Postby ggroess » Wed Oct 27, 2010 1:17 am
true enough...it is about your work flow...use it as you like....
