Steve Canyon ex 4
Life after CM...I'm not sure...I'm betting there is..but I seem to keep running into the CM Class... :o
A couple of quick things...
1) there is a green cast over the entire image. Try setting a neutral to bring that back. It is most likely left over from the color contrast move. If you do this in LAB and you do not return the curve to neutral somewhere along the line you you will see the colors shift. Set a hue clock on a part of the image you want to keep neutral in the image before you do the contrast move. then use the arrow keys to return the curve to a place where the contrast move is there but the color cast is gone...
2) When you remove the color cast the shadows turn a bit blue...See shot 1
3) The bright greens might be too far...they draw your eyes out of the frame.
- shot1-jpg-26 (257.11 KiB) Viewed 35219 times
