julie tiger
Postby imported_julie » Thu Oct 21, 2010 2:17 am
Hi Greg
this is my lab attempt.
First I did the shadow highlight neutral and saturation. I then used the hue clocks to get a good look at the colour. IMy screen shot only sows one channel sorry.
I saved and then went back into lab and tried to get the neutrals more neutral. I know i could have gone to rgb but decided for the sake of the exercise to do it all in lab.
I tried to use the numbers as well as the colour in the hue clocks. this is as close as I could get it to neutral
now i have looked at it maybe i could have tried to lighten the shadows a little particuarly the interesting bark on the tree
tigerlab1-jpg
tigerlab1-jpg (999 Bytes) Viewed 5618 times
tiger-lab2-jpg
tiger-lab2-jpg (999 Bytes) Viewed 5618 times
2008-01-30_142354_02-jpg
2008-01-30_142354_02-jpg (999 Bytes) Viewed 5618 times
Postby ggroess » Thu Oct 21, 2010 2:05 pm
The LAB version look solid...maybe a slight bump to the orange in the tiger by making both an A and B curves adjustment.
See screen shot and try loading the ACV I have as well.  Use your image and load my ACV.
Since Orange is red and yellow you need to pin the blue and green down so it does not shift...
screenshot005-jpg-10
screenshot005-jpg-10 (174.91 KiB) Viewed 5618 times
2008-01-30_142354_02-labgg-acv
(90 Bytes) Downloaded 637 times
