I have tried this several times. Not doing great.
I ran CM used mask- first screenshot. Sorry, I did not capture the mask.
Then I saved the mask and inverted it on the mask of a different layer. I lighten up the foreground (screen shot 2). Then I did a little channel mixer to lighten the greens.
(by the way I am traveling this week, so I may not fix the other images because I do not have the original corrections. I would have to correct from scratch, which is doable and might be preferable. But I am short on time).
Steve example 3 view from temple
Steve,
This one took me a while...
OK the explanation is pretty simple but; I was having trouble with the sky color overall.
It is too cyan and that cast runs all over the entire image. Since you were working LAB I tried to make my corrections in LAB as well. Since there is no neutral I used a Pin from the pins folder called Glencoe Sky. Since the Greens are also in trouble I adjusted the A curve to help them out...
In fact from where the image is right now a RGB correction is pretty tough...
I have attached the acv file.
- screenshot002-jpg-31 (103.17 KiB) Viewed 9497 times
- 53-lake-lab_gg-acv
- (86 Bytes) Downloaded 762 times
- screenshot003-jpg-16 (180.74 KiB) Viewed 9497 times
Yep, too cyan. The real answer was to fix the b curve after trying to colorize it. Colorizing (with LAB) seems to push skies into cyan. I think that is easier to fix after lab curves than trying to fix a better sky value.
Pins: When I pin, it pushes the curves in the "right" direction. Sometimes (?) the pinned point is not the same value as the pin. In LAB, for example, the a and b seem to be right, but the L may differ. I assume that in RGB and HSB the act of pinning fixes the color but sometimes leaves a point darker or lighter than the pin.
CMYK: heavy sigh, it works after a fashion. For example, when I bring up the mask cart the K mask is fixed. I cannot change GCR. If I go to wg cmyk and back, I get that option. It is not an obvious system. I guess if no one else complains, it is me.
Check the Pin Mode..Sometimes they are set to Hue and saturation but not brightness.
See shot1: the top red mark shows a right click point. You will get the fly out menu shown in Shot2.
the bottom red marked area has a marker for de-activating the pin. this allows you see the effect of the pin and decide what you want to do.
Let me kick this one around a bit...what version of CM are you running now...
- pin-marker-jpg (30.67 KiB) Viewed 9497 times
- pin-marker2-jpg (167.56 KiB) Viewed 9497 times
