Rhonda 20 faces improved
Postby mikemeister_admin » Thu Oct 14, 2010 9:55 pm
Here are the off-tone faces with some improvement.  When is it appropriate to use the other skin pins?  I can look this up if it is posted on the site somewhere.  I used #8 for one or two.
20-corrected-skin-tones-jpg
20-corrected-skin-tones-jpg (999 Bytes) Viewed 7145 times
Postby ggroess » Thu Oct 14, 2010 10:46 pm
Skin Pins are very subjective.  They are tools to get the tones back into a place where they look right....
Have you read the advanced skin tones work flow article??  In it we show you how to make your own pins from a color sample and a method for getting close with the tone...
The CM skin pins are for You to have something to go on...They can and should be added to as you need...
Postby mikemeister_admin » Fri Oct 15, 2010 8:15 pm
Thanks, Greg.  No I had not yet read the skin tones workflow article.  I will do so and revisit the Abe Honest video.
How behind can I get and still keep plugging at the class?
Postby ggroess » Sat Oct 16, 2010 2:41 am
The boards will stay open to you for 2 years and I'll answer a question anytime...
I'll keep working with you until you are done if need be...
