skin pins
If you blew out your settings in the 3.2.4 install...I did...
If you are in WIN7 you can find them in the application data folder. It is hidden by default in Win7 so you have to show hidden folders first then...
All usersapp datacurvemeister.com...etc...
Otherwise if you follow the links you can get the txt file and add it via "manage pins"... It is also found in the Pins thread out on the main forum...Copy it from there if you like.
Thia photo is at the bottom of the class links page. "Challenge images"...
