Building using Photoshop Only
Postby mikemeister_admin » Sat Sep 18, 2010 7:32 am
I'll work on the image using Curvemeister but wanted to see what I could do in Photoshop first.  I'm not a Photoshop whiz, so I just did a curves layer, then upped the vibrance a bit, raised the brightness and contrast a touch and sharpened it.  Took me about 10 minutes.
I've now spent an hour in CM with no good luck.
Greg, shall I try to duplicate this in CM, or head in a different direction?
building-using-photoshop-only-jpg
building-using-photoshop-only-jpg (999 Bytes) Viewed 5253 times
Postby ggroess » Sat Sep 18, 2010 1:14 pm
Rhonda,
Try this in CM but don't try to be too fancy, just set a good neutral, find the thresholds use the Lab saturation slider to add color overall.  It really should only take 5-7 minutes...If it takes more post you image and let's see what's going on.
