julie statue
Postby imported_julie » Fri Sep 17, 2010 8:44 am
I did the exercise and also added a litle contrast, maybe not enough. Sharpened a little but it was very grainy and then went back after saving the acv file and added more colour. Since I have no idea what the real colour is it was a bit of a guess but I dont think I have blown the highlights. Maybe?
oops got it wrong I will ry again.
statuelab-jpg
statuelab-jpg (999 Bytes) Viewed 5677 times
c01s01-example6-jpg-2
c01s01-example6-jpg-2 (999 Bytes) Viewed 5677 times
statue-jpg
statue-jpg (999 Bytes) Viewed 5677 times
Postby ggroess » Sat Sep 18, 2010 12:49 am
She is a tad bit dark...but you can try the adjustment shown in the screen shots...
Her color is good and it is consistent.  The sunlight on the torch tells me it should be a bit brighter...
Shot1 shows the area to be concerned with..
shot2 shows a reasonable result.
screenshot001-jpg-60
screenshot001-jpg-60 (61.88 KiB) Viewed 5677 times
screenshot002-jpg-44
screenshot002-jpg-44 (59.99 KiB) Viewed 5677 times
