You can be quite selective in HSB about the range of color you are desaturating. The Hue and Saturation curves can be adjusted quite easily...in fact. The trouble is that the gray tone does not match up with the rest of the image for warmth and feeling.
What to do with this church image?
Highlights,
From the thread you posted.
http://www.flickr.com/groups/delaboratory-users/discuss/72157627970443017/
A lot can be done without damage to the subtle colors in the walls and furniture.
For this correction I used Curvemeister and did the following:
1) use the Daylight to incandescent stored curve in CM. Apply the change and close CM.
2) re-open in CM and apply a skin tone Pin to some skin tones in the portrait...They should look right in any case...Applied the curve and closed CM.
3) re-open in CM and adjust the yellow channel in CMYK to remove some of the foreground yellow. It was a slight change...
Some things to note...I think the method you are showing really kills off some of the more subtle colors in the image. The light green in the walls is very important to the overall image and the color of the carpet while not perfect is certainly more brownish green than a off gray. I think you have the right Idea but color correcting the kinds of color casts you are working on really is better suited for RGB. you have a more fine control of the color space and the shadow, mid-tone, and highlights can be adjusted separately.
Lab is powerful but like a hammer when it comes to color casts. You might want more of a paint brush or even a feather duster when it comes to important color corrections. I'll try out the mandolin image and see what I can do with that...
- 6333010045_67f6c6dc03_b_cm_butterfly-jpg (280.15 KiB) Viewed 11981 times
CM is a great tool. but it is just a tool. The things you learn in the CM101 class and practice can be applied to any program with curves. Do not take my adjustments as the definitive answer. There are certainly more ways to correct this image. Lab is very addictive and fast but it has it's weak points. It is one of my most powerful tools but you have to be careful what you use it on.
Your tools can produce the same results as CM. I just took some short cuts...the Stored ACV and the color pins are additions to CM not the main process. Please keep asking questions and we'll keep putting answers out there for you.
It's about the image not the tools...
thnx
I did look a bit a your image, Hope you don't get mad. Though i think you have a green cast (can be very good seen) next to that small protrait on the stove. Though that green cast is every where . It goes all over the image. See the table and the couch left f.i. I think you did perhaps focus to much on the painting instead on the WB and WP / BP edit : just saw you also got a slight blue cast on the (dont know the English word) that thing around the stove.
Also a yellow / green cast on the walls next to the doors. I am sure those walls are white as can be. Also you seem to have a slight red cast on the sealing. I had problems there too. Though as try to fix WB the wall doe give us a white point. If one does have cast still there one needs to check more imo. I think value's are of a great help there. Also i feel that the devastating effect casts often is underestimated. Talking about a hammer ;-) Cast sure is one. I have learned, first to get WB WP BP right, work from there. Or if one does go for artistic affects np. Though for a starter like me it feels the way to go.
Btw on this image one needs to be careful or one blows the highlights out side. Btw to prevent it i did use for EV correction not LAB though CMYK K channel.
It aint that easy.
i did try an another shot.
i think., i am getting closer. Thnx to you i did also check more on the photo above the stove. I think i got it ok now. (was not so for sure) Lab is indeed a hammer, though it feels good to me, for sure on WB fixes., i think , i hope i just have to practice more.
Must i am after a relook not to happy also on what i have now. The floor is indeed to much desaturated. , it aint easy
It aint that easy.
thnx
The walls are in fact Green. As is the chair and the glass of the table..note the white towel and the visual contrast between it and the chair. The white trim on the fireplace and the upper trim around the room are most obvious places to look for a neutral white.
The skin tone pin on the portrait is more of a landmark for finding correct color. With all the cross casts in the image the portrait should look good. It is a place the eye will expect correctness. The fireplace measures black using the hue clock in Curvemeister.
See note above re: the real color of the walls...Sorry but they are Green...
That is the curtains reflecting on the ceiling
You are correct in getting the Color balance figured out but when your starting point is so far off as in the original it is difficult to correct this image without an "rough" correction first to get you close. You need to choose better memory objects for determining the neutral points. If the trim of the room is white and the walls have tone there must be color in the walls that belongs there.
The exterior is not "that important to the overall image...It is about the room interior and that is where most of the correction is focused. The Exterior could be brought back into the image with a mask and a multiply layer. It was not the main point of my correction and visually I had no problem with leaving it too bright. It provided a nice counter balance to the dark fireplace.
It aint that easy.
Agreed...but it is also not impossible...
Lab is certainly the easiest color space to think in.. It is considered a perceptual space and is very much in line with how we "see" color. It is on the other hand severely limited in how it handles mixed lighting. It would not be my first choice in color correcting an image this far out of balance.
Does your program allow you to use RGB color space? if so try to make adjustments in that space first to get the image closer to the correct balance..then try LAB to make minor adjustments...
Keep at it...Keep asking questions.
Hey Greg,
You got me on a better track.
When using LAB (still feel it is great to fix WB issues, and my idea to move the center points according to marker values can be a great assist, if not a very good to perfect way to deal with the issue) One has to be sure to choose the correct points of correspondence. As you did point to me. Thnx!!! A big help is do look during the process very well to what the light is doing in the picture. Be aware of false assuptions (as i did first by thinking the walls should be white. You are right they are not! As you said the color differences are very subtile. I have values though miss your color clock. To bad the clock made by Chris also does not work on linux. :-(
The couch and the walls. To my current findings it has some slight greens and some slight yellows in it.
So i did do it over again working with three reference points.
1 Did start with cover on the stove
2 A point at hard point on the ceeling where also the red cast can occur.
3 A point a the grass in the picture on the wall above the stove
I think i am very close now. There one color in the image that does bother me now. And that is the brown in the floor. If i look at that it tells me i am close but not really quite.
I tells me i went to hard on the reds, (prolly correcting the sealing) ?
See:
We did pick a hard image to get real good. Though those are the once one gets better by.
For me i rather start in LAB and go to CMYK for the final touch. When one needs to be real subtile Luminance blending CMY channels seems to me then just great. (or if one does like RGB in RGB, though i am no RGB dude) That man from mars methode that other guy (http://livestre.am/DSAO) did show, does blow my mind off. He sure is on track there imo.
Though some how his way does not work in the program i use :(
It is atm still very beta, though if you want to check it. a windows version is here. http://code.google.com/p/delaboratory/downloads/list (export option does not work there, fixed in svn) As said i use linux svn version .
Post script:
I did check on the value's have now on the shadows on the portraits on the stover cover. (how is that one called in proper English ;-)
those should have imo a close to natural grey?
I know the guy who did make the shoot somehow, i could ask him about the wall colors as we only have educated guesses. You feel it dif, though i think i even still have a green cast. (color overlay that not should be there and covers other colors)
Btw on LAB beeing a hammer, I do not know or CM does have a curve fine control by f.i keyboard control. Aka for the very small moves on a curve a kinda micro adjustment?
I did try software that has Ctrl + mouse wheel for per pixel up or down and Shift + mouse wheel for per pixel left and right. It does not support layers and values. :-( So they have a great micro adjust though one still walks blind fouled.
Btw i have a European background. so it might i just look diff couse of that.
That is also why i like this methode, it goes by values and light. all is free from there.
See:
Post script:
I know that for some of you this is going too far from the original posting but highlights has asked a good question and deserves a good answer....
To take the Lee Varis image he linked to through a similar process....
Shot 1 is the original Image with CM hue clocks on "critical" areas. I put this inquotes because the choices are somewhat subjective but reflect the goals you should be having for your images...
I have placed hue clocks on the faces for skin tones and on the watch band and head band as target black areas. I do not know if the head scarf is white but for now I would guess that it is not. I also mark some highlight areas in the background so I can get a scope of how severe the cast is out there. Notice that the skin is off colored and the shadows are cold
Note: This picture is about the people. The background will be adjusted as much as possible to make it look better but I do not know what color the glass behind them is and if it is causing the color shift to be more severe than I would think it is.
Shot 2 is the image with the adjustment curves.
I applied no masking to this image I simply used RGB to adjust the colors based on the brightness range which is RGB's strongest feature. I reduced the blue overall in the image and made the people look better. I did not try to remove all of the color from the background I simply muted it a bit.
Shot 3 is the compare image the correction is on the left and the original is on the right.
Some thoughts...
The technique used by Lee Varis and highlights is the opposite of the color expansion process we are beginning to teach people. Using LAB to kill off the color cast is a very dangerous way to go down a road that is better driven with RGB. The loss of yellows and blues is especially visible since most of us are very yellow blue sensitive. There is a loss of color fidelity that is most disturbing to the eye and poorly restored at the end. While we might have to resort to these kinds of correction in a rare picture; they are not good mainstream techniques for general color correction. I fear that the loss of color fidelity is written off in the goal of getting rid of any color cast.
In his final image which I'll attach in the next post he has killed off the color in the background to emphasize he people and illustrate the technique.
Some thoughts...
- varis_111001-3551-2_original-jpg (207.57 KiB) Viewed 11981 times
- varis_111001-3551-2_rgb_cm-jpg (225.17 KiB) Viewed 11981 times
- varis_111001-3551-2_butterfly-jpg (280.09 KiB) Viewed 11981 times
