Do Pins Work In 64 Bit Beta?
Postby mikemeister_admin » Sat Aug 07, 2010 9:57 pm
Greg and or Mike:
Do pins work in the beta?  I have not been able to access them.  I tried to load Greg's skin tone pins (although recognizing that these might only work in 32 bit) and they are not showing up and I am getting error messages when I try.  If they should be working I'll take another stab at it.
Brian
Postby ggroess » Sun Aug 08, 2010 2:23 am
Mine work just fine Brian...
The screen shot attached shows the path I have my pins located in...
screenshot001-jpg-67
screenshot001-jpg-67 (41.95 KiB) Viewed 24901 times
Postby -default » Mon Aug 09, 2010 3:39 am
Hi Brian,
Right click on the pin palette and find the Manage Pins... command.  This will show you the folder where Curvemeister expects to find your pins, and you can copy them there if necessary.
