Win7(64bit) /CS3 and CM3Demo installation
This board is for new users looking for some help between the Curvemeister classes.
Postby mikemeister_admin » Sun Jul 25, 2010 10:28 am
I need your valued assistance please.. I am installing CM3 demo but get the following error message: Registration of some of the ActiveX controls and/or Type libraries failed.... The following controls could not be registered C:program files (x86) Curvemeister.comCurvemeister_3democurvectl3.ocx.
I do have VB redistributables installed
Any suggestions will be appreciated
Gerhardt
Postby ggroess » Sun Jul 25, 2010 2:03 pm
In Win7 you need to disable the user account control for the install of CM.    If you re-install with the UAC turned off this should allow the control to register...If not post back and we will help you get it done through the regsrv32 process..
Postby mikemeister_admin » Sun Jul 25, 2010 3:28 pm
Thanks Greg, such a quick response was not expected!  I have turned off UAC by selecting " never", restarted but still get the error message on installation. Would appreciate further assistance  Regards
Gerhardt
Postby ggroess » Sun Jul 25, 2010 4:32 pm
One way to do this is to manually register the OCX file.
Use a command window and at the prompt type "regsvr32 curvectl3.ocx"
This should register the ocx in the 32 bit space...
Postby mikemeister_admin » Mon Jul 26, 2010 7:00 am
Thanks Greg, attempted that with little windows knowledge and some memeories of DOS but get a 'Failed to find file' message I have copied the files into the same directory but to na avail. Any further help will be appreciated
Regards
Gerhardt
Return to “Help Me! I'm new and I need some help”
