Returning to the theme of CurveMeister offering a level of quality that cannot be matched by Photoshop, I think that there is scope for improving the way that curves themselves function within the plug-in (or hopefully, standalone application ;)).
Something that Photoshop allows users to do to a curve (if you are tone mapping an HDR file) is add corner points, rather than the bezier points that normal curve interfaces use. If you've not used this before, adding a corner point is optional - it's not the default behaviour.
Corner points would enable users to lock down an area of a curve with a single point - something that currently requires two or three points. This would be especially helpful for the a and b curves in Lab.
Corner points would also be helpful when working in the centre of the a and b curves because they would enable finer control.
Because the a and b curves are so sensitive, and because common pixel values are located at the centre of the curve grid, at the moment I usually need to place 3-5 points very close together to control colour the way that I want to. The only reason that I need to use so many points is because I cannot use corner points. With corner points I could probably do what I need with just two points. Not only would this make my curves look more elegant, but - importantly - I would have better control of my curves.
I would also (in returning to a saved curve file/or a curve created via a Smart Filter) be better able - at a glance - to understand what each point was controlling. Quite often I use lots of points on a curve, but most of them are not doing anything (they are just locking the curve to the baseline). This is a side-effect of having to always use bezier curves even when I want a straight line.
I've looked into the math of defining bezier curves - adding a corner point option would appear to be a whole lot simpler. It also raises the bar again, and offers potential users another compelling reason to give CM a try.
What do you think?
Corner Points
Quick-mod tools
1 post
• Page 1 of 1
Jump to
- General discussion
- Learn about the new forum
- Other Languages!
- Interesting Images
- Help Me! I'm new and I need some help
- Equipment
- Software
- Affinity Photo Program
- Discussion Group
- Announcements and New Versions
- Curvemeister Techniques
- Creating Masks With Curvemeister
- Color pinning
- Photoshop World
- Jacob's Ladder
- What's your Workflow
- Tips and Tricks
- Photoshop LAB Color Book
- Articles from other forums
- Photo Assignments
- The Curvemeister Challenge
- Want us to work on one of your images?
- Curvemeister 3 Beta
- Magpie Beta
- Curvemeister 4 Beta
- CM201 Beta Testers
- Questions about Photoshop and Elements
- Report Curvemeister Bugs
- Missing Manual Pages
- Curvemeister Support
- Vote on and Discuss New Features
- Enrollment
- CM101 Discussion Board.
- CM 101 - January 2017
- Curvemeister 101 - March 2016
- May 2007 Curvemeister 101
- June 2007 Curvemeister 101
- July 2007 Curvemeister 101
- August 2007 Curvemeister 101
- September 2007 Curvemeister 101
- January 2008 Curvemeister 101
- September 2008, Curvemeister 101
- November 2008, Curvemeister 101
- July 2008 Curvemeister 101
- Curvemeister 101 June 2009
- Curvemeister 101 January 2009
- Curvemeister 101 March 2009
- Curvemeister 101 September 2009
- Curvemeister 101 December 2009
- Curvemeister 101 March 2010
- Curvemeister 101 June 2010
- Curvemeister 101 September 2010
- Curvemeister 101 - December 2010
- Curvemeister 101 June 2011
- Curvemeister 101 - January 2012
- Curvemeister 101 - July 2012
- Curvemeister 101 - March 2013
- Curvemeister 101 - August 2013
- CM101 1 Week Refresher Course
