Used L channel to bring out bird droppings on spire,an approach used by several people in previous classes.GregM
Luminosity sharpening set to 25% opacity.
St Vitus
- st-vs-cath-copy-jpg (999 Bytes) Viewed 9708 times
- st-vs-cath-copy-lab-acv
- st-vs-cath-copy-rgb-acv
- st-vs-cath-copy2-jpg (999 Bytes) Viewed 9708 times
- st-vs-cath-copy-jpg-rgb-acv
It's nice to see another correction of this image :)
I've been working with your curves (thanks for attaching them, it's always a real help), and presume that you did your first pass in RGB (to set the white point)... I really like the idea of using the bird droppings. I wouldn't have thought of that in a million years! I also like the drop on the highlight endpoint in Lab - knocking down the brightness of the pavement really helps the image.
Nice work - thanks for sharing ;)
Greg M,
Interesting take on this but.....
The shadows are still blue... See hue clocks...your correction also does not address the skin tones in the background.
- st-vs-cath-copy-jpg-rgb-acv-2
- (58 Bytes) Downloaded 737 times
- shot1-jpg-75 (299.73 KiB) Viewed 9708 times
