Week 4: Exercise 6 - Fire Engine/Exercise 7 - Yellow Car
Postby leeharper_admin » Sun Jul 04, 2010 8:39 am
Hi Greg  :)
I've still got two exercises from week 3 to finish, but I thought that I'd get two quick exercises out of the way from week 4 before I get to those...
The fire engine was easy - just invert the a curve in Lab. I liked the effect a little better with a K mask applied, but since that's not what the exercise called for I'm just uploading the image as is.
For the car image, I kept the negative halves of the a and b curves where they were (more-or-less, I did add a tiny bit of saturation to the green grass); I flattened the positive half of the a curve - taking all of the red out of the image; and finished by steepening the positive half of the b channel.
As suggested, I lightened the car in the L channel, which made it look a lot better. Returning to Photoshop, I decided to use the 'Blend If: A' sliders (set to underlying layers) to bring the grass more in line with the uncorrected image. I didn't completely revert it, as I think a slight saturation boost makes the grass look better, but on reflection the colour of the grass created by my (attached) curve did look a bit radioactive, so I wanted to knock that back a bit.
wk4_ex6_lh-jpg
wk4_ex6_lh-jpg (999 Bytes) Viewed 10343 times
wk4_ex7_lh-jpg
wk4_ex7_lh-jpg (999 Bytes) Viewed 10343 times
wk4_ex7_lab_lh-acv
Postby ggroess » Sun Jul 04, 2010 12:58 pm
the car is a bit hot as well...if you are going to go further...
On the fire truck it is possible to keep the skin tones in line...up for a challenge??
screenshot001-jpg-72
screenshot001-jpg-72 (158.78 KiB) Viewed 10343 times
screenshot002-jpg-53
screenshot002-jpg-53 (131.73 KiB) Viewed 10343 times
Postby leeharper_admin » Sun Jul 04, 2010 4:01 pm
Always  ;)
Happy 4th July by the way  :) I hope you're enjoying yourself!
Postby ggroess » Mon Jul 05, 2010 5:44 am
Thanks Lee; I had a fine Day...Went to the history museum here in St Paul to see an exhibit about Ben Franklin.  Very interesting guy...quite the ego...
Postby leeharper_admin » Mon Jul 05, 2010 9:54 am
Thanks for the challenge  ;) It was fun having another go at the fire engine, and trying to limit the adjustment to the engine (although in the end I decided to steepen the b channel to add some more saturation to the sky and natural greenery).
It was a really simple curve to write, as there was so much separation between the skin and the engine in the a channel (I've attached the curve in case you want a peek at it).
I also set shadow, highlight, and neutral points, and added a little contrast in the L channel - something that I hadn't done in the other version I posted, so this is also a little snappier.
wk4_ex6_v2_lh-jpg
wk4_ex6_v2_lh-jpg (279.02 KiB) Viewed 10343 times
lab_v2_lh-acv
(106 Bytes) Downloaded 766 times
Postby ggroess » Mon Jul 05, 2010 3:18 pm
well done...
These are pretty easy curves to write...as you say...
