When work on skin tones in CM one of the biggest hurdles is knowing what "Skin Pin" to set. I have created a few resources for you to use and build upon.
Lastly is the work flow...
Pinning Skin Tones in CM - Advanced Workflow.
Just a quick note to thank you for uploading this PDF. The gradient/foreground/background technique is amazing! I have been wondering for the last few weeks about why on earth being able to pin things to Photoshop's foreground and background colours would be helpful. This technique is genius!
I've been correcting skin tones all day, and have found CM really helpful. The skin tone mask has helped me out a few times, and I'm just loving the workflow :)
I will get back to this week's exercises tomorrow. I'm loving this course ;D
Thanks so much,
Thanks so much,
