Pumpkin
Postby mikemeister_admin » Sat Jun 26, 2010 5:47 pm
After some work on the brightness channel to bring out the under pumpkins and a saturation boost I went to cmyk and moved the magenta curve a bit for the final color.GregM
  Go USA
2007-10-15_172735-copy-jpg
2007-10-15_172735-copy-jpg (999 Bytes) Viewed 8541 times
Postby leeharper_admin » Sat Jun 26, 2010 7:52 pm
Thanks for posting that Greg - it's great to see another interpretation of this image  :).
I'm also finding it really interesting learning about how other people approach corrections. I will definitely have to have a go at working it in CMYK (when I'm more comfortable with CMYK  ;)).
Postby ggroess » Sun Jun 27, 2010 3:01 pm
Hey Greg,
Can you add back some of the shape...I think it needs just a bit more...On my screen it lots a tad flat....
screenshot001-jpg-74
screenshot001-jpg-74 (151.87 KiB) Viewed 8541 times
2007-10-15_172735-copy-jpg-wgcmyk-acv
(58 Bytes) Downloaded 621 times
Postby mikemeister_admin » Sun Jun 27, 2010 10:25 pm
Reopened image.My initial move  in brightness sucked vitality from the image.I was trying an alternative to a lizzard tail.GregM
Pump3 image is done according to Mike's  instructions(when all else fails read the instructions)
pump2-jpg
pump2-jpg (296.54 KiB) Viewed 8541 times
pumpsnap-jpg
pumpsnap-jpg (291.51 KiB) Viewed 8541 times
pump3-jpg
pump3-jpg (247.05 KiB) Viewed 8541 times
Postby mikemeister_admin » Mon Jun 28, 2010 10:11 am
I think that the storks in version 3 are much better than version 2 (in v2 they look too blue, and over saturated - at least on my screen). I like the colour of the pumpkins in v2 more though...
Lee  :)
