Hi,
Is there a version of curvemeister that woud work with illustrator on rasterized vector?
JPD
curvemeister for Illustrator cs3
Hi Jeanne Pierre,
No - Illustrator does not support the kind of image data that Curvemeister uses. If you had an image in Illustrator that you wanted to curve, you would need to export it as a raster image, and then curve it in Photoshop or Elements. By the same token, placed art would need to be curved before placing in Illustrator.
If I didn't understand your question, or otherwise not provide the information you wanted, please let me know.
