Week 1: Examples 1,2,7, and 8
Postby leeharper_admin » Mon Jun 14, 2010 3:05 pm
I have attached my curve files for these examples. The ones with clean in the title are versions where I tried to remove the jpg artifacts in the file, in addition to improving the contrast.
With examples 7 and 8, I probably could have moved the interior curves even further (sending the gray background on the left to black), but I felt that I should keep the background on the left lighter than the background on the right.
week1_example1-acv
week1_example2-acv
week1_example1_clean-acv
week1_example2_clean-acv
week1_example7-acv
week1_example8-acv
Postby ggroess » Mon Jun 21, 2010 2:39 am
OK...I finally got a look at these...
You did a fine job with these simple corrections.  # 8 can be a bit tougher but you certainly got the concept down.
