Has anyone successfully installed and used CM 3.0.18 on Windows XP SP3, Adobe Photoshop Elements 8? The 3.0.18 worked fine, which is why I purchased the product. Now, after *finally* getting the purchased product installed, it crashes on each invocation.
Any thoughts? Advice?
Thanks in advance
CM 3.0.18 and Elements 8
Hi - I also responded to your ticket on where to download the newer version, which I believe will fix this problem Please let me know if this does not fix the problem, or if you have any additional questions.
The ticket system is somewhat preferable because I can post serial numbers and download locations more freely there, but you can use the forum if you prefer.
Return to “Help Me! I'm new and I need some help”
