Week 6 Example 4 Taroko Gorge
kessi
Postby kessi » Tue Apr 20, 2010 8:41 am
I struggled to get this pleasing and I am not happy with the rocks and the water in the foreground. Somewhere I overdid the curving and there is a weird look to them.
Kessi
c1s6-example4-taroko-gorge-jpg
c1s6-example4-taroko-gorge-jpg (999 Bytes) Viewed 45900 times
screenshot-taroko-gorge-jpg
screenshot-taroko-gorge-jpg (999 Bytes) Viewed 45900 times
Postby ggroess » Tue Apr 20, 2010 4:40 pm
Kessi,
The answer to where you overdid the curve is actually in your screen shot.
The area I have circled is creating the "flatness" you are seeing.  It is right on the verge of solarization.  If you tone this area down a bit you should get more out of the image.
Regardless of how you tackle it the L channel is the culprit.
screenshot-taroko-gorgegg-jpg
screenshot-taroko-gorgegg-jpg (267.77 KiB) Viewed 45900 times
kessi
Postby kessi » Wed Apr 21, 2010 7:30 am
Thanks, will fix it.
Kessi
