Week 6 Example 3 Ceramic dragon and warrior
kessi
Postby kessi » Thu Apr 15, 2010 5:37 pm
I really tried to punch up the colours. I set Hue clocks to get the green more green and the blue away from cyan.
Kessi
c1s6-example3-ceramic-dragon-warrior-jpg
c1s6-example3-ceramic-dragon-warrior-jpg (999 Bytes) Viewed 55176 times
screenshot-pagoda-ceramic-warrior-jpg
screenshot-pagoda-ceramic-warrior-jpg (999 Bytes) Viewed 55176 times
Postby ggroess » Fri Apr 16, 2010 4:44 pm
You indeed did punch it hard...
I have to say too hard...It is possible to drive the detail out of the image with saturation...the areas shown are where I look to see if you over saturated the image...
See the comparison below...
The original image is the lower half ...your image is the upper half...
compare-jpg-3
compare-jpg-3 (297.08 KiB) Viewed 55176 times
kessi
Postby kessi » Sat Apr 17, 2010 6:47 am
Back to the drawing board for me.
Postby ggroess » Sat Apr 17, 2010 1:29 pm
not too far back..
Just watch out for lost details...balance that against the gains in color and punch...
kessi
Postby kessi » Mon Apr 19, 2010 8:27 am
I think this is a better attempt.
Kessi
c1s6-example3-ceramic-dragon-warrior_gentle-jpg
c1s6-example3-ceramic-dragon-warrior_gentle-jpg (228.04 KiB) Viewed 55176 times
Postby ggroess » Mon Apr 19, 2010 3:52 pm
That works....Much better...
I found that I could add some saturation to the image after you were done but not so much as to say you should re-do it...
I would say you got this one figured out.
