Week 5 Example 5 Grafiti
kessi
Postby kessi » Tue Apr 13, 2010 10:13 am
I feel more confident with masks now.
I used the G Channel mask and popped the colours with a and b channel. I then lightened the image a bit more by moving the L channel. Maybe I should have rather curved it, but it does not look like I lost detail.
Kessi
c1s5-example5-grafiti-mask-and-lab-jpg
c1s5-example5-grafiti-mask-and-lab-jpg (999 Bytes) Viewed 35219 times
screenshot-grafiti-with-mask-and-lab-jpg
screenshot-grafiti-with-mask-and-lab-jpg (999 Bytes) Viewed 35219 times
Postby ggroess » Wed Apr 14, 2010 1:28 am
Kessi,
What an interesting way to go about this...do you find the trees in the back to be too bright??  I know that is always an issue but they are a small part of the overall image.
Did you try these with L or K to isolate the letters on the wall only??
Not that your correction is wrong...I'm mostly curious now as to what your thought process was...
kessi
Postby kessi » Wed Apr 14, 2010 5:57 am
I used the G channel and just went boldly forth.
The trees in the background might be a smidgen bright but I thought it gave the overall picture a friendlier feeling.
Kessi
Postby ggroess » Wed Apr 14, 2010 11:49 am
I like going forth boldly...that is always a good thing...
Good job!
