Week 5 Example 4 Lemurs
kessi
Postby kessi » Mon Apr 12, 2010 6:21 am
My new mantra:
"The mask should be dark for the areas to be protected"  ::)
My lemurs with a b channel mask and a saturation adjustment. Also increased eye colour by moving mask curve up a bit.
Kessi
c1s5-example4-lemurs-jpg
c1s5-example4-lemurs-jpg (999 Bytes) Viewed 26831 times
Postby ggroess » Mon Apr 12, 2010 7:00 pm
The Lemurs look good...you could even push it a bit further for color if you want...seems like the mask is doing the job...
