Week 2 Example 2 Children Drawing
kessi
Postby kessi » Sat Mar 20, 2010 7:22 pm
My version of the Children Drawing in Lab. It is not as bright but that way I can read the small letters.
kessi
c1s2-example2-children-drawing_lab-jpg
c1s2-example2-children-drawing_lab-jpg (999 Bytes) Viewed 7366 times
kessi
Postby kessi » Sat Mar 20, 2010 7:35 pm
My RGB version. Even darker than Lab, but the colours are a bit more luminous.
c1s2-example2-children-drawing_rgb-jpg
c1s2-example2-children-drawing_rgb-jpg (256.54 KiB) Viewed 7366 times
Postby ggroess » Sat Mar 20, 2010 11:24 pm
Both look like you still have the right idea here kessi.  The RGB version could use a tweak to the Master curve if you want to.  It's more of a brightness issue.
