This is my RGB version. I tried to keep the neck of the horses as defined as possible without going into blow-out mode.
cheers
kessi
Week 2 Example 1 Merry-go-round
For the RGB version you could bring the mid-tones down a bit as shown in the screen shot. this will add even more depth to the colors. You are getting much closer with the neutrals..Remember that in RGB you can have a color shift in both highlight and shadow ends of the curve so if you chose a darker neutral it might still allow a color shift in the highlights.
- screenshot002-jpg-65 (155.67 KiB) Viewed 8938 times
