Week 1 Example 6 Liberty
kessi
Postby kessi » Sat Mar 13, 2010 9:11 pm
I preferred the Lab mode although RGB is very similar. I added a point in the centre of the curve to bring out some light on the right hand side of her face. No much though.
Kessi
c01s01-example6_liberty_lab-jpg
c01s01-example6_liberty_lab-jpg (999 Bytes) Viewed 8507 times
Postby ggroess » Sat Mar 13, 2010 10:15 pm
This is quite the subjective image...one does not quite what to do with the sky...I do know this though...Green sky is not as pleasant as a warm sky...
Your shadow and highlight were great, the lack of a neutral makes you work hard for the right color. People would  just would rather see neutral to warm rather than greenish.. . If you look at the slight bend in the A channel above the center of the grid you can see a small change makes a huge difference.
You are not that far off Kessi...
screenshot002-jpg-67
screenshot002-jpg-67 (85.66 KiB) Viewed 8507 times
kessi
Postby kessi » Sun Mar 14, 2010 6:17 am
Me and green again. I'll work on the picture to get it right.
Kessi
Postby ggroess » Sun Mar 14, 2010 3:56 pm
no worries...it is early in the class...
