Interpret this as though it were your own.
Postby ggroess » Tue Mar 02, 2010 1:38 am
I have adjusted this image so many times I always see something different in here...
See what you can do with this...So far there is no right answer...but plenty of wrong ones....
point-reyes1-jpg
point-reyes1-jpg (999 Bytes) Viewed 13729 times
Postby imported_ganna » Tue Mar 02, 2010 8:04 pm
Used the building as a neutral. Everything else in Lab
point-reyes-jpg-2
point-reyes-jpg-2 (168.14 KiB) Viewed 13729 times
Postby ggroess » Tue Mar 02, 2010 9:47 pm
any thoughts about why you chose the depth you did and what other ideas crossed your mind??
Postby imported_ganna » Wed Mar 03, 2010 3:55 am
It looked like the mist is clearing; thus early morning, but normally after sunrise and therefore I thought your image was a little too dark.
Postby ggroess » Wed Mar 03, 2010 4:04 am
interesting...the fog was rolling through the scene and there were moments of clear sky it was actually mid-afternoon.
The image as posted is certainly too dark and that is one of the problems to tackle...
Postby mikemeister_admin » Thu Mar 04, 2010 4:57 pm
I used the building as the highlight,shadow in bushes and neutral on a tree trunk.After a color boost,I moved the lightness threshold to the right and the saturation slope changed to the included curve.GregM
A bit of cyan can be removed from the sky to change the mist.
point-reyes1-copy-lab-acv
(70 Bytes) Downloaded 929 times
point-reyes1-copy-jpg
point-reyes1-copy-jpg (279.49 KiB) Viewed 13729 times
point-reyes1-copy2-jpg
point-reyes1-copy2-jpg (277.59 KiB) Viewed 13729 times
point-reyes1-copy-wgcmyk-acv
(58 Bytes) Downloaded 879 times
Postby ggroess » Thu Mar 04, 2010 10:20 pm
Boy I'm tossing them both up...which one do you like better??
Postby mikemeister_admin » Fri Mar 05, 2010 1:02 am
The misty version???GregM
Postby ggroess » Fri Mar 05, 2010 1:42 am
nice....
Thanks for the help
Postby mikemeister_admin » Sat Mar 06, 2010 4:45 pm
Well you do come up with some strange images
There are too many jpg artifacts in the sky area to really go mad, but that doesn't stop me.
- so I've gone more weird than normal to try and breathe some strangeness into it !
point-reyesz-jpg
point-reyesz-jpg (142.5 KiB) Viewed 13729 times
