See what you can find when you get this image into better shape.
Find all the colors in this image...
Georg,
not bad...
The greens are a bit blue but we'll talk about that later in the class. Typically we want greens to be on the yellow side of green rather than the blue side. Have you seen the hue clock in the upper Right side of the CM frame??
You can use the hue clock to check the color using the mouse. Just hover the mouse over the spot on the image and it will give you a fast look at the hue of the sample under the mouse.
Your Shadow and Highlight look solid and the mid-tones maybe could use a tweak; overall it looks pretty good.
not bad...
- shot1-jpg-88 (32.68 KiB) Viewed 13472 times
