Hi,
Elements crashes immediately when i try to use Curvemeister from the filters menu.
I have Vista 64-bit, PSEelements 7.
I have tried version 3.0.15, 3.0.18 and 3.0.19.
Any suggestion how to resolve this problem?
Problems with PSE7 and curvemeister
Remember that 64 bit Vista does not equal 64 bit Photoshop.
If you PSE 7 running in Vista X64 you really have a 32 bit Photoshop and need the 32 bit version of CM to make it go right...
If this is not the case the 32 bit version of 3.0.19 is working on my Win7 64bit with PSE8 and it worked with PSE7 as well. Did you install the VC run time software?
